Difference between the Blue and Yellow Clutch Spring
Don't know if this is what you're looking for... hope it helps.
37882-06 blue dot (117 KgF/258 lbs/ft) 2006-88", 2007 thru 2010-96"
37871-04 yellow dot (135 KgF/ 298 lbs/ft) 2004-05 88" and 2010 Limited
37871-98A (145 KgF/ 320 lbs/ft) 1998-2003 Most recommended on forum for touring
37807-03 pink dot (165 KgF/ 364 lbs/ft) 2007 thru 2010-103 "Police"
37951-98 (175 KgF/ 386 lbs/ft) Current SE
Harley1004 (01-23-2021)
samsquanch (02-17-2021)
Another reason I chose this spring as some were stating that the 37951-98 spring was a little too stiff having difficulty engaging clutch. Another person complained of developing a case of carpal tunnel.
I imagine this depends if his / her scoot was driven mostly highway, or city and factor in the strength of the individuals hand. If your scoot has an hydraulic clutch then this doesn't apply, then I would install the heaviest clutch spring available.
Just my two cents,
B Bop
2012 FLHR (Road King) Stage II Red Ember Sunglo/Merlo Sunglo, Original HD Chrome Laced Profile Aluminum Spoke Tubeless Rims, ABS, Cruise Control, Security Package, Saddlebag LED Spoiler lights, and array of nostalgic & high performance accessories that enhances appearance & blood curdling performance.
It’s a shame there is nothing available today that can measure white knuckles & big a$$ smiles.
