Notices
I give up.....
Old 02-04-2012, 05:49 PM
Gliden's Avatar
Gliden
Gliden is offline
Smile
Originally Posted by Bill03E
Wrap a piece of a plastic license plate around the grip lube it up with soap, slide them on one at a time.
I don't get it......? A piece of a plastic license plate?
Tell me more. I'm not too bright...
Old 02-04-2012, 06:12 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
maybe try a piece of plastic from a gallon milk jug, cut it square/rectangle and roll it up into a cylinder/cone put your rubber piece on it and slide it over the end of your grip then slide it off....worth a try i guess...
Old 02-04-2012, 06:28 PM
James K's Avatar
James K
James K is offline
Originally Posted by Gliden
I sound like such a lil bitch....it was so stressful.........
BUT IT WAS!........lol
Old 02-05-2012, 09:00 AM
Gliden's Avatar
Gliden
Gliden is offline
In theory your right. It needs something like that but these bands are so thick it would crush the gallon of milk plastic. The bands are a thick tight 11/16 in diameter and need to stretch to 1 1/4 to go over the grip and snap into place.
What's needed is some sort of PVC pipe or cone device which is as tough as a piece of PVC pipe but it needs to be one smooth piece which starts at 1/2 inch and gradually makes it's way up to 1 1/4 inches.
Then yes you could use that to lube and slide these suckers on. Without that it's 2 pair pliers some soap, boiling water, cursing naturally and some luck.
Old 02-06-2012, 10:16 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
how about you start with this and modify it by slicing it part ways length wise....
http://www.ebay.com/itm/Transmission...item2c61a15bb6
Old 02-08-2012, 05:53 PM
Gliden's Avatar
Gliden
Gliden is offline
Holy crap that's hysterical cause I think that would have worked!
What's worse is I have that funnel about three feet away from me. Omg. You and the hot water guys win!
08FXDL
08-24-2016 08:32 PM
MichaelCummings
04-25-2013 01:49 PM
CobraEd
04-19-2011 06:13 PM
hockey8787
02-24-2011 11:54 PM
Quick Reply: I give up.....
