Ohlins in OZ
Question on Ohlins 3'3.. Haven't installed mine yet but from 9 clicks on the rebound from top setting when solo riding...when I go two up and with tour pak loaded on my SG...do I need to adjust me preload or can I just adjust the rebound rebound few clicks to say 6....?
If I were to adjust the preload..what would be avg turns CW I should go for.two up with loaded tourpak?
I thought about denting my after market pipe too. Be warned! If you have after market pipes with removable baffles you will never get the baffles out if you dent the pipe. I found the best way is to put a 1/2" spacer between the rear mounting bracket and pipe. You will hardly notice the difference.
