Removing Rotor from Inner Primary
Old 01-27-2012, 08:20 PM
aviscomi's Avatar
aviscomi
aviscomi is offline
Default Removing Rotor from Inner Primary
Does anyone have any tips on removing the Rotor from the Inner Primary on a 103"? I am in the process of swapping out my engine for a 120r and I can only get the rotor to the end of the spline before it hits the inner primary.
Old 01-27-2012, 08:26 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Only way to get it out without removing inner primary is to grind that lip from about 5 o'clock to about 10 o'clock. Many, including myself, have been faced with this when upgrading the compensator. Doesn't take long and in no way harms the casing.
https://www.hdforums.com/forum/touri...it-w-pics.html
Old 01-27-2012, 08:39 PM
rlaf75's Avatar
rlaf75
rlaf75 is offline
+1 on the grinding. its very easy and like stated before, it wont harm the case. definately beats pulling the primary off
Old 01-27-2012, 08:47 PM
mglax13's Avatar
mglax13
mglax13 is offline
Can't wait to see it with the 120R!
Old 01-27-2012, 08:57 PM
aviscomi's Avatar
aviscomi
aviscomi is offline
I need to take the inner primary off too. I assume then the rotor will come off with it?
Old 01-27-2012, 09:08 PM
slyder's Avatar
slyder
slyder is offline
Yeah........take the inner primary off first.
Old 01-27-2012, 09:17 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
+1 on grinding in place.
Old 01-27-2012, 09:20 PM
Udawg's Avatar
Udawg
Udawg is offline
I love the paint on your limited. In 11 they reversed it.
Old 01-27-2012, 10:09 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
Not many people are reading your post thoroughly. If you are pulling the engine, then obviously your primary has to come off. The rotor does not come off at all until the inner primary is completely removed, then you can slide the rotor right off. Make sure after you get your new engine mounted up, slide that rotor back on before you start installing the inner primary.
You DO NOT need to grind on your primary.
Old 01-27-2012, 10:26 PM
soft 02's Avatar
soft 02
soft 02 is offline
Yes but if for any reason in the future he has to get to his stator he will wish he had ground it!
Quick Reply: Removing Rotor from Inner Primary
