Broken "Y" Pipe
Old 01-26-2012, 09:21 AM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
Best thing I ever did was ridding my bike of that POS 'Y' pipe. You can cut it off and patch it or contact Fulsac and install one of they're kits.
More than many of those 'Y' pipes actually extend into the pipe they were joined with causing an obstruction to exhaust flow. Two of mine did exactly that.
Old 01-26-2012, 11:45 AM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
Its a common occurrence unfortunately. Some do it quickly & others never at all. My 98 FLHT broke a couple as did my 07 SG. I went to a V&H Pro Pipe on the 98 & V&H Duals on the 07. Problem solved.
You have to take it off to repair it anyway so if you have the $, good time to got a different route.
Old 01-26-2012, 12:55 PM
sargek's Avatar
sargek
sargek is offline
Also make sure the little "L" shaped (?) bracket that mounts the "Y" pipe to the top of the starter is not cracked. That is if your '05 has one - my '07 does and I can't speak for other years. It's relatively cheap and easy to replace. The "Y" pipe was the first thing to break on my '07 - I found one on ebay for cheap and just replaced it.
Old 01-26-2012, 02:22 PM
hougz79's Avatar
hougz79
hougz79 is offline
Hope your new pipe works out for you. Best wishes.
Old 01-26-2012, 04:15 PM
bigskyhd's Avatar
bigskyhd
bigskyhd is offline
Same thing happened to me this last fall. My buddy had a new OEM takeoff so I did the same thing. Just part the program if you really put any miles on your bike.
Old 01-26-2012, 04:44 PM
beary's Avatar
beary
beary is offline
Originally Posted by Firebike32
Had it happen on our '02 a few years ago. Middle of South Dakota, Labor Day week end, 80 MPH. Blew a chunk about the size of a half dollar out.
Happened on my 02 as well. I was told it was more common on 02s than most other years, something to do with the angle of the exhaust on the hanger under the saddle bag.
Beary
Old 01-26-2012, 05:00 PM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
yep mine to , one more thing I like about the ESP , $50.
Old 01-26-2012, 06:11 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
{ www.fullsac.com } Check it out and dump the Y pipe altogether.
Old 01-26-2012, 06:18 PM
littled62's Avatar
littled62
littled62 is offline
Originally Posted by Guntoter
You may need a front motor mount also. When they wear out it lets the motor move around quite a bit more, breaking the weld on the rear Y pipe.
mine cracked on the way back AZ last summer, turns out the front motor mount was als broke, lucky still under extended waranty by 6 months, told me that most of the time when the Y Pipe cracks its because of a broke motor mount, so make sure you look to see if it is broke
Old 01-29-2012, 02:15 PM
pit1600's Avatar
pit1600
pit1600 is offline
happened to me 2 years ago. Very expensive part...
Quick Reply: Broken "Y" Pipe
