Lost Tranny Vent Tube - idea's
01-25-2012, 09:30 AM
Lost Tranny Vent Tube, no idea where it went, arrrg...
Anybody running a aftermarket set up ? Pictures would be great
01-25-2012, 09:35 AM
Quote:
Originally Posted by
trackadaptor
Harley for the pre-bent tube. Not sure why they do not use a spring cap but some implied it was internal? Remember it vents primary also.
01-25-2012, 09:43 AM
Looks like my 2007 FLHX set up, these new '09 is just 1 Vent tube , no threads just a open hole...
RIPSAW
01-25-2012, 09:44 AM
Just a chunk of hose will do the job.
01-25-2012, 10:02 AM
What's wrong with HD OEM?
01-25-2012, 10:27 AM
Location: Western Illinois, land of bad roads, and corrupt politicians
Just go to your dealer and pick one up.... they are about 4 bucks.
01-25-2012, 10:29 AM
trackadaptor
My 04 is just like picture to right. Just an inverted formed hose. At minimum you do need the inverted formed hose. That is why I would bite the bullet and get it at Harley. The spring vent valve I show is what is on your typical car/truck manual transmission or differential. My 4x4 has them with a tube attached to that and extended up about 2 feet. It allows vent out but in theory at least prevents water entry and small critters?. HA
01-25-2012, 10:51 AM
You might put a clamp on the new hose. Now that this has happened to you, I'll check mine and clamp it before it falls off.
01-25-2012, 05:25 PM
$3.89 7-10 days looking for aftermarket....looks like theres none...i'll buy 2
Hose will not stay on '09 up models.....
thanks
shooter5074
01-25-2012, 10:02 PM
Never had a problem with the vent tube hose on my 09.
