What have done to stop oil from leaking from air cleaner?
Old 06-15-2012, 09:55 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
If you look at the design, it incorporates a venteded area in front of the TB. Im not crazy about using those cheesy rubber hoses and I dont think you need both 90s. By routing a T to the center one you can clean the area up. Id like to use a rigid tubing but attaching it to the OEM nipple requires inginuity but hey we ride HDs were used to pulling rabbits out of our a$$es to make it work.
  #72
Old 06-17-2012, 05:13 AM
boom23's Avatar
boom23
boom23 is offline
I am not sure if this has been mentioned, but has anyone tried these breather bolts?
http://www.dkcustomproducts.com/All-...ngines_c76.htm
  #73
Old 06-17-2012, 12:12 PM
Tortoise98's Avatar
Tortoise98
Tortoise98 is offline
Received 2,284 Likes on 837 Posts
Originally Posted by iwillfixthem4u
I'm tired of the oil leaking from my air cleaner, what can I do to stop it?
http://dohertymachine.com/index.php?...26b1d3dea5373b
expensive, but it works
  #74
Old 06-17-2012, 03:53 PM
caper's Avatar
caper
caper is offline
Originally Posted by Tortoise98
These work pretty good too....and only around $13 bux each...
Attached Thumbnails What have done to stop oil from leaking from air cleaner?-breather-ass-top.jpg   What have done to stop oil from leaking from air cleaner?-breather-ass-bottom.jpg   What have done to stop oil from leaking from air cleaner?-17025-03a-breather.jpg
  #75
Old 06-17-2012, 06:27 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Great idea but the bolt thread length is not nearly long enough to go through the backing plates and into the heads. If they did, I would jump on it and give it a try.
  #76
Old 06-18-2012, 06:32 AM
98Ultra's Avatar
98Ultra
98Ultra is offline
Where does this mount? Got a pic?
  #77
Old 06-18-2012, 07:07 AM
psychocircus's Avatar
psychocircus
psychocircus is offline
Originally Posted by chilly1962
Exactly. Don't lug it. It will greatly reduce any blow by.
clown...
how you been man?
  #78
Old 06-18-2012, 10:22 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
This is the route Im going if mine all of a sudden starts to **** oil from my breather.....I had to deal with this on my Metric but Im not doing it with my RK...not when theres a kit like this for a fix.
  #79
Old 06-18-2012, 11:08 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Before I pull the motor apart, I'll try the copper tubing set-up......Now if it was winter time, that might make a slight difference on pulling parts off of the motor....
  #80
Old 06-18-2012, 04:12 PM
caper's Avatar
caper
caper is offline
Under the top rocker cover on the rocker arm support plate....
Here's some pics of it being done...to go one step further would be to remove the rocker support plate and enlarge the drain back holes to 1/8"....but guys have noted an improvement just doing the breather upgrade
http://www.americanbagger.com/pdf/breather.pdf
Quick Reply: What have done to stop oil from leaking from air cleaner?
