Aux. stereo plug/mono plug: how do I tell the difference?
I have been reading on here about the different issues with different Aux. plugs for the HK radio. I bought a right angle plug for the ZUMO 550 but cannot recall if I bought stereo or mono. I bought it some time ago and no longer have the paperwork. One member here says it has to be the stereo plug or it won't work.
Is there a way to look at the plug to find out which I have? Thanks.
A stereo plug will have two conductors separated by an insulating partition...while the mono will only have one conductor.
Check this out...
http://support.radioshack.com/SUPPOR...oc68/68379.htm
I hope this helps...
Steve
Check this out...
Steve
Don't know the specifics of this but he does know his stuff, and I have certainly noticed that not all plugs are created equal. I have also experienced real quirky behaviours with cig lighter sockets and plugs too. In short, I always err on the side of better quality leads and never force something in.
Incidentally, the rings are in fact an insulation material that separates the various sections of the plug so you can run multiple transmissions up a single plug
depending on the dimensions "chosen" by the maker, a "mono" plug may short the ground and right audio in a stereo jack ( plug= male, jack = Jill )
stereo plugs are tip= left/ ring= right/ barrel is ground. ( apple variation may use a 4th ring for video/control/mic in)
a "mono" plug may have it's insulating blocks at non-standard/non compatible intervals
as referenced above and in my post on the other thread, some suppliers alter dimensions slightly, making a "sure thing" into a crap shoot.
if a plug ever feels super tight going in, stop, remove it and return it.
mike
mike
dchoran
04-16-2006 01:00 AM
