best engine oil
Old 01-17-2012, 09:24 PM
Bushy's Avatar
Bushy
Bushy is offline
Wesson in the Primary and Crisco in the Crank.... Canola in the Tranny
Old 01-17-2012, 09:37 PM
davewear's Avatar
davewear
davewear is offline
I'm a fan of amsoil and use to run it in all 3 holes but find I get better clutch feel with non syn in the primary, I run formula + there.
Old 01-17-2012, 11:03 PM
BackRoader's Avatar
BackRoader
BackRoader is offline
+++1 on the Red Line!
Old 01-18-2012, 10:33 AM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
After two days of trying to get the Crisco in the crankcase oil hole I switched it to the primary (can put in with spatulla) and running the Wesson in the crankcase. Then my wife told me to melt the Crisco first and pour it in. Im not switching it now. BTW + 10mpg and +22 mph.
Run what you think is best. "Syns are better for the heat".
Old 01-18-2012, 10:45 AM
Terrabella's Avatar
Terrabella
Terrabella is offline
Default Give the guy a brake
Originally Posted by deepsea
I just moved over here from the sportster side. What is the best engine oil for a 07 road king with 96ci engine. I ran mobile 1 synthetic 15w50 in the engine and 75w90 in the primary of my sporty. What do you all use?
Poor guy, he just asked a question that has been answer on other post a million times. For every option on what kind of oil to use, the are a bunch of opinions all of which are the users choice. You'll have to make your own decision on this subject. Pros and cons on every oil made for V Twins all of which will do a decent job of protecting your bike. You will have to make the right choice based on your OPINION.
Old 01-18-2012, 10:53 AM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
K. Op. Guys are having good luck with amsoil,red line,mobil 1 etc. I personally like red line and use shock proof in the tranny,rotella in the primary and whatever v-twin synth is on sale at the time. Synth handles the heat better and you can run it for 5000 miles. If you are gonna use Dino change it every 3000 miles.
Just pay attention to your bike. As the oil gets worn the top end will get louder,telling you the oil isn't protecting as well as it was. Listen to the bike,learn it's sounds. It will tell you
Old 01-18-2012, 10:58 AM
baust55's Avatar
baust55
baust55 is offline
In my 96 twin cam i run:
crankcase Mobile-1 V-Twin 20w50
primary Mobile-1 T4 10w40
tranny Mobile-1 75w140
Old 01-18-2012, 11:02 AM
SugsPa's Avatar
SugsPa
SugsPa is offline
There's some great info in the "Tech" section. Worth the look.
SugsPa
Old 01-18-2012, 11:59 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Interesting statement as I determined a non synth in my primary gave me a better feel with less noise also....just not mentioned much. I've been using Rotella T in the primary, if you've used it in your big rigs you'll know Rotella can take serious punishment. Mobil 1 full syn 20/50 In engine with M1 75-90w in trans.....seems to be a good combo. You can see how all over the place everyone is on oil.
Old 01-18-2012, 01:24 PM
Nut08Ultra's Avatar
Nut08Ultra
Nut08Ultra is offline
I use a mix of canola and Crisco... it makes my bike smell like a french fry vendor goin down the road... its great!
Sorry.. couldn't resist.
Serious answer... The ones I've used I really liked were Mobile one, Lucas. I hear amsoil, Royal Purple, Redline, and some others are top of the line and have the price to match. I have also used Castrol Act-Evo with good results.
The rule of thumb you will hear is that unless you try to keep your oil in for extended use for some reason, you can use almost any brand and change it when you should.
I do have to say that I used Syn3 once in a 99 FXD I had, and drained out all out after 3 rides because I thought someone poured quarters into my primary it was so loud. Threw Mobile one and Valvoline gear oil their approriate holes and it was like a totally different bike from the Syn3. Although I heard some people say it was ok, I stay away.
Quick Reply: best engine oil
