Dyno / Power Vision - a Little confusion
Old 01-15-2012 | 10:21 PM
jackhis's Avatar
jackhis
Default Dyno / Power Vision - a Little confusion
I am slow, so I have to ask!
I have read many threads, but my little brain couldn't take too much info in the same time. I just installed a TW6-6 cam, with SE adjustable pushrods, stock lifter, Fuelmoto power package (PCV stage 1 A/c, 3.5" Jackpot exhaust system).
I have a question:
If I buy a Power Vision tuner from Fuelmoto, does the bike still need to be Dynoed?
Of course, I will talk to Jamie later, but I'd like to hear your experience about the Power Vision.
Thanks much for any info.
Old 01-15-2012 | 10:32 PM
Lowcountry Joe's Avatar
Lowcountry Joe
There is no rule that says you "must" have your bike tuned.
Sounds like you recently added the cams, and you already had all the rest of the stuff bolted on, including the PCV. So why do you think you need a Power Vision?
Call Jamie and get a map for your PCV that is good for your new cams when combined with your existing hardware. Bet he has one that will work well.
Ride the bike for a while and then if there are issues, call him back for refinements based on your feedback. If after you have exhausted all options, you can always find a good tuner and go that route. That's my 2 cents.
Old 01-15-2012 | 10:33 PM
XARAN's Avatar
XARAN
You can dyno it, or go with the custom MAP jamie will send you and if you want to dial in more or if you feel its not quite right use the data logging feature of the Power Vision to self tune the bike. So with the PV you can tune without a dyno
Old 01-15-2012 | 10:40 PM
kingkingking's Avatar
kingkingking
+1, this guy knows his ****....
Old 01-15-2012 | 10:53 PM
jackhis's Avatar
jackhis
Thanks much for the info.
Jamie told me that he will send me a new map on monday, and I hope that will improve the MPG, which is the main reason that I want my bike to be tuned.
Money is tight, so I've been thinking about buying a PV for the long run vs. Dyno, which required to be done everytime I do an upgrade.
IF the PV can tune the bike to an acceptable condition, then PV is the way to go, but I have not learned enough to have a confidence in the PV yet.
whynotf75
07-11-2015 07:20 PM
3/4 life crisis
11-19-2013 09:26 PM
rleggs
10-28-2013 08:51 AM
skull and bones
04-26-2010 11:14 PM
Rambone1570
12-24-2009 07:11 AM
Quick Reply: Dyno / Power Vision - a Little confusion
