BRAKE UPGRADE
Old 12-12-2006, 03:19 PM
anubisss's Avatar
anubisss
anubisss is offline
Default RE: BRAKE UPGRADE
PM calipers here...The bike came with them so I have no frame of reference. But I saw a RK recently that had pm's on the front dual disk. Floating rotors will always help you stop better...
There is the rear, don't really have a goodpic of the front. the front is the 6 piston...
anubisss's Avatar
anubisss
anubisss is offline
There is the rear, don't really have a goodpic of the front. the front is the 6 piston...Oh yeah, I have the stell braided cables and lines as well shich supposedly help. I need all the help I can get with a 700 lb bike...
Old 12-12-2006, 03:28 PM
WISHBONE's Avatar
WISHBONE
WISHBONE is offline
I WENT AHEAD AND BIT THE BULLET FOR PERFORMANCE MACHINE SIX PISTON FRONTS (2) AN FOUR PISTON REAR ON MY 2000 ROADKING AND I HAVE GOT TO TELL YOU THAT MY BRAKES FEEL TWICE AS GOOD AS MY BUDDIES NEW 2007 SCREAMIN EAGLE ROADKING. JUST MY TWO CENTS WORTH !!!!!!
Old 12-12-2006, 04:56 PM
UGGA's Avatar
UGGA
UGGA is offline
ORIGINAL: Biggzed
I think you could improve your stock set-up fairly economically by adding floating rotors, Lyndall Racing Brake pads, stainless braided lines.
This is exactly the setup that I'm running. Barnett platinum brake lines, HD floaters and Lyndall Z pads. The bike stops very well. Here's a pic.
Doug
Old 12-13-2006, 12:00 AM
Big Cholla's Avatar
Big Cholla
Big Cholla is offline
On my '05 Road King Classic, I simply went to 3ea. floating rotors and didn't change anything else. I will eventually go to Lyndall Zs, but my OEMs were just fine for now. I now have much better braking with less pressure required. There is no noise of anysort. I am very pleased. ............ BC
Old 12-13-2006, 10:17 AM
DI75's Avatar
DI75
DI75 is offline
I switched to PM from stock. Not one bit better except in looks!!
Old 12-13-2006, 10:23 AM
Hdbiker1450's Avatar
Hdbiker1450
Hdbiker1450 is offline
it's my understanding that floating rotors will stop the grinding noise you hear at slow speeds. I also remember someone saying it will stop the 'grab' I feel on my (and most everyone else with one) 02 RK.
My question is this--Are they hard to install? Is this a do it yourself job?
Old 12-13-2006, 10:38 AM
stafford's Avatar
stafford
stafford is offline
Thanks HDBIKER1450. My RKC stops great with stock brakes. I don't see how it could be much better. Stafford
Old 12-13-2006, 05:39 PM
Big Cholla's Avatar
Big Cholla
Hdbiker: Yes, you can do it yourself. Get the H-D Service Manual and follow their instructions.
You will need:
Blue Loctite.
Torque wrench in ft./lbs.
10 mm x 3/8 in drive socket with 12 points not 6
Tube of 'anti-seize.
Torx wrench for the rotor cap screws.
Wrenches in correct size for axle nut an axle keeper nut.
You might need the correct size allen wrench for the axle keeper head to hold while loosening and tightening.
Some clean rags.
If you have more than 12k to 15k miles on your bike, you might be ready with new brake disc pads.
If you go with chrome rotors, you might want to pre-purchase H-D's aftermarket chromed rotor screws (5 ea.).
Be aware that removal of the rear wheel is easily twice the job as the front wheel. Go slow and read the manual.
Good luck, ......................... BC
Old 12-13-2006, 05:45 PM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
13 inch rotors, six piston calipers that should throw you over the bars and passenger also. Develop a grip!
Quick Reply: BRAKE UPGRADE
