Rear Brake Squeak
RE: Rear Brake Squeak
If you can, try cleaning the rotors with some scotchbrite and if that does not do it, then take the pads off and clean them with some brake cleaner and then put them back on. Brake squeel is kind of normal with ductle iron rotors. If you want to stop it for good, you are going to have to upgrade to a better brake pad and floating rotors.
Good luck!
[IMG]local://upfiles/494/62BF7C61764146E7B81392D3AA2D6807.jpg[/IMG]
Good luck!
