I am going to put on 10" PY Bagger apes. It says that the 1 piece riser clamps must be used. Yaffe has a clamp, but it's twice the cost as the stock HD part. and I have found may cheaper alternatives on eBay. Does anyone know if the Drag specialties cheap one listed on eBay will replace this 1 piece HD one. Do any other HD models use this same clamp? I'd like to know so I can possibly find a used one on eBay.
My 06 did not have the one piece clamp. That was done after 07, I believe. Go with the HD clamp. good quality and made for your bike. You don't need a fancy chrome one, it it will be out of sight under your dash.
I used the HD one-piece on my '04 EG--p/n 55918-08. I also replaced the riser bolts with the shorter headed version HD introduced to avoid contact with the bottom of the HK radio--p/n 12600003.
I used the HD one, new, no problem. My buddy found an used one somewhere else and no problem too. It's not where you have to spend lot of money, a used one will work
I took the one piece HD clamp and drilled and tapped to holes in it. Then put a set screw on each side to lock down ontop of the bars. Bars are solid as a rock.
While doing in there I would also change out the riser bushings for the updated HD ones.
