Unbelievable! Trim rings on with NO gap
Old 01-13-2012, 04:52 PM
Scarz's Avatar
Scarz
Scarz is offline
Default Unbelievable! Trim rings on with NO gap
I put some visor trim rings on my headlight and passing lights today. Followed the directions and NO gap. And, didn't have to use any clamps as others have suggested.
Old 01-13-2012, 06:01 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Looks good. So what's the problem?
NCPiper (01-11-2022)
Old 01-13-2012, 06:14 PM
Redbeard719's Avatar
Redbeard719
Redbeard719 is offline
Veteran: Marine Corp
Received 1,226 Likes on 550 Posts
I got no gaps either, at least up front on the headlight. If I look from underneath, there is a gap at the back of the seam.
Looks good!
Old 01-13-2012, 06:16 PM
jmacdonald5's Avatar
jmacdonald5
jmacdonald5 is offline
....hey...what's with the GAP at the 6'oclock position?....JK..nice job!
Old 01-13-2012, 06:20 PM
Guest
Guest
Posts: n/a
no gaps for me either... though i did use a clamp or 2 on the headlight just to be sure. I think following the supplied instructions very carefully was the key however
Old 01-13-2012, 06:23 PM
bald1der's Avatar
bald1der
bald1der is offline
No Gaps here either
Old 01-13-2012, 06:41 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
Once in awhile Murphy takes a day off.
Old 01-13-2012, 08:17 PM
jberg's Avatar
jberg
jberg is offline
Directions say to slightly loosen the original ring to allow the new one to settle into the space between the housing and the ring. You won't have a gap if you do it right.
Old 01-13-2012, 08:22 PM
Tee Bagger's Avatar
Tee Bagger
Tee Bagger is offline
Getting ready to get me a little gap....oh, headlight..sorry!! Lol!!
Old 01-14-2012, 02:28 AM
Jon0807's Avatar
Jon0807
Jon0807 is offline
I must've done something wrong cause I followed the directions, even loosened the screw quite a bit. I still have a gap.
Quick Reply: Unbelievable! Trim rings on with NO gap
