Unbelievable! Trim rings on with NO gap
Old 01-11-2022, 01:47 PM
Ultra103's Avatar
Ultra103
Ultra103 is offline
Received 1,053 Likes on 541 Posts
You guys may want to start a new thread, this one is 10 years old.
Old 01-11-2022, 01:49 PM
DLawson's Avatar
DLawson
DLawson is offline
6th Gear
Wow HD Rider, that looks nice
Old 01-11-2022, 01:55 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 18,220 Likes on 7,377 Posts
My daughter works for Old Navy that owns Gap. Otherwise I cannot be of help.
j
Old 01-11-2022, 02:00 PM
07UltraGuy's Avatar
07UltraGuy
07UltraGuy is offline
Received 6,210 Likes on 2,244 Posts
FWIW, I have a french visor-style ring on mine, and it has a very small gap at the bottom; I had to install it w/o the factory ring underneath to get it this close.
I don't mind because it is rock solid tight, and I can't see it from behind the fairing.
Old 01-11-2022, 02:51 PM
NoRegerts's Avatar
NoRegerts
NoRegerts is offline
Received 8,953 Likes on 4,700 Posts
Not saying you're wrong, but as soon as they did, someone else would scream to use the search function.
The following 2 users liked this post by NoRegerts:
07UltraGuy (01-11-2022), Ultra103 (01-11-2022)
Old 01-12-2022, 12:51 AM
RJ69's Avatar
RJ69
RJ69 is offline
Thank you !
Old 01-12-2022, 12:55 AM
RJ69's Avatar
RJ69
RJ69 is offline
The "I can't see it from behind the fairing" part is where I've been with it for 5 years but when the parts & service guys come out last Saturday and say, "That's not right"....It stirred this **** up again for me.....yet, they had no solution and I have to say that it seriously bothered them and they were set on finding a solution....and they did not.....
Old 01-12-2022, 12:58 AM
RJ69's Avatar
RJ69
RJ69 is offline
...and if I'm not mistaken, removing the stock ring also means you removed the rubber gasket that is supposed to keep bugs & water from getting behind the bulb?
...all they had to do was make the french trim ring the same as the stock ring so that we could remove the stock ring and replace it with the french trim
Bobby12012
10-22-2014 02:11 PM
billbuzz
03-11-2014 08:53 PM
ejvette
05-14-2012 07:33 PM
shagnasty
02-21-2010 09:47 PM
Yogi
04-10-2007 02:46 AM
Quick Reply: Unbelievable! Trim rings on with NO gap
