Notices
Brass balls
Old 01-12-2012, 12:39 PM
mike_oh's Avatar
mike_oh
mike_oh is offline
Originally Posted by mike_oh
How would a piece from the transmission get in there??
Seriously...that is a big chunk! I would think it had to come from somewhere inside the cam chest tho....Good Luck!
Old 01-12-2012, 01:03 PM
DHubbs's Avatar
DHubbs
DHubbs is offline
Could it be a piece that came loose on the top end & fell down through a push rod tube?
Old 01-12-2012, 01:09 PM
JRGarrett's Avatar
JRGarrett
JRGarrett is offline
5th Gear
I almost think it might of been added by a tech before I owned the bike. My bike spent the first 25k of it's life working for the Fort Worth Police dept. and since i've owned it no one else has worked on it. I could just amagine a tech saying F the police and adding some shavings to the motor.
There really is no place in the cam chest-plate area where a piece this size could have come from unless im ignorant. Just wish there was someone who could say i know exactly where that piece came from or i came from outter space ?
Old 01-12-2012, 01:17 PM
Big Trev's Avatar
Big Trev
Big Trev is offline
I suspect it's been in there since new, when I done the SE cam plate up grade I found a small stone laying next to the oil pump in the timing chest.
Old 01-12-2012, 02:06 PM
JRGarrett's Avatar
JRGarrett
5th Gear
There is no way this piece would fit through the push push rods. Do you guys know who the best tech guy is on here or a good TC 88 machinist i could talk to?
Old 01-12-2012, 02:13 PM
JRGarrett's Avatar
JRGarrett
5th Gear
I almost believe your right but i want as many opinions as possible. I'm going back together with new cams and oil pump and wonuld hate to blow it up right away. Thanks man.
Old 01-12-2012, 02:18 PM
Dewky's Avatar
Dewky
Dewky is offline
take off the oil filter and cut it open.You will see much more if something is coming apart in there.I dont think you would find such a large piece without there being a lot of other smaller pieces.
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
Sabotage...
Old 01-12-2012, 02:40 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
The only other bronze piece in the motor I can think of is the valve guide, but I have no idea how a piece of valve guide could get into the cam chest.
I wouldn't be putting that motor back together if it was mine. The whole thing would be coming apart.
Wonder if someone was using a brass drift to put new cam bearings in and a piece came off? Just thinking out loud.
Zach
Old 01-12-2012, 07:29 PM
Mike's Avatar
Mike
Mike is offline
check your pinion shaft bearing in the cam support plate.
Quick Reply: Brass balls
