Wiring Zumo 660 to Accessory Switch?
#41
Talldog,
What kind of bike do you have? Have fun with your GPS and just relax. As others have said the 660 is pretty much trouble free. Give us some pictures when you get the GPS mounted and wired in.
Morris,
Thanks for the link. I don't even remember the site I got my last file from. I will try the one from Zumo. Again Thanks
Morris,
#42
Talldog,
Morris,
Morris,
Registered at Garmin and downloaded the latest Software and Maps.
![](http://i5.photobucket.com/albums/y193/tractor56/IMG_0486.jpg)
![](http://i5.photobucket.com/albums/y193/tractor56/IMG_0487.jpg)
#43
found your thread about wiring and plugs..im planing on using the plug you mentioned two into one OEM # 70264-94..was wondering if you had some sort of wire diagram that i cold fellow two wire up a socket??...i want to run my gps and detectable pizza box lights.i see the plug thats there now has for pins...
#45
thanks shooter for speedy reply...so if i got this right,to use the acc switch,the two wires from the GPS unit..one is ground ( BLK ) and one Hot ( red ) the hot will go to the orange and the blk will go to blk gound,,,and if i want marker lights from the trunk to be on when ignition is on i wire the to the green and splice into the blk for ground..YES???
