Wiring Zumo 660 to Accessory Switch?
I think what I'm gonna do is just hook into the Orange/White and Black wires by the Headlight connector. As long as I can do a hard re-boot with the battery, I see no need to have it switched.
You guys saved me some work!
I used the 91843-97. While it comes with a cigarette socket, I just cut that off. The Duestsch plugs right into the black deutsch under the seat and is controlled by both the ignition and switch on the Nacelle. They run between $ 15.00 and $ 19.00 depending on where you buy it.
It saved a lot of work for me when I installed my garmin. Mine is soldered to a wire wire flat plug and I did the same with the garmin lead.
I have mine hard wired as well. Occasionally it acts up and needs to reboot. You can remove the battery or a much quicker way is to hold down the + and the power button at the same time for about five seconds. This will force a reboot without even having to remove the GPS from the cradle.
Location: Western Illinois, land of bad roads, and corrupt politicians
![Icon Lolsign](https://www.hdforums.com/forum/images/smilies/icon_lolsign.gif)
I agree with some of the other posts. If the unit ever does lock up, chances are that you will not be able to reboot it simply by turning off the power. You'll probably have to remove the battery.
If that's the case, there's nothing to be gained by removing the gas tank and tapping into the accessory switch. It would be much easier just to find a switched hot wire in the fairing and tap into it. The GPS pulls so little current that it's doubtful that it will put any strain on anything you use as a power supply.
The only advantage I can see to tapping into anything else would be to tap into a source that was hot all the time and turn the unit off and on with the switch on it. The advantage would be in that if you are using the GPS to guide you and you stop for gas when restarting the bike you'll have to wait for the system to boot and reload the map and route. This does not usually take long but I guess it depends on how much of a hurry you are in to get going again.
The downside of doing it that way is that you'll have to remember to turn it off each time you get off the bike.
You'll need to figure out what's more important to you and wire it to suit that.
For my 550, I tapped into one of the headlight wires. The unit goes on and off with the ignition.
Shooter
I have the Zumo 550. I must have assumed Incorectly that the two models were built similar. I still bet it has this override feature somewhere. Most electronic devices have a way to reboot them. May be as simple as holding down the power button. I know on the 450 and 550 you have to hold the + and power button but saves taking out the battery which on mine is held in by a small screw. I have a connector in line so I can remove the whole cradle. When it locks up unplugging the power does nothing as to a reboot. The artery has to be removed or hold down the buttons for a hard reboot.
Shooter
I don't actually have the GPS "in hand" yet, is the reason for all these dumb questions.
Still got ya.... if a 660 is messed up enough that you have to reboot it.... you need to remove the battery to clear it.
Most of the time the power switch will fix things. If it doesn't then you have to remove the battery.
The good news is, the 660 is actually very stable. I have only had to hard boot mine ONCE.
You gonna love it no matter how you install it.
Yes it will hold the route.... and when you shut off the bike it asks if you want to stay powered with internal power, and then does a countdown before it shuts off.
