Great buy on Scissor jack
Was looking to get a scissor jack to use on the lift table when I wanted to work on the wheels. Found this on E-bay for a great price. It's a K&L Fat Jack scissor jack with the wide platform for $209.95, FREE SHIPPING. And that's a bonus because, this jack is heavy duty. This jack can vary on price and I have seen it as high as $349, with this price the lowest I have ever seen. You can also get the dolly for it. I have seen the others that sell for $79-$109 but, they are not built the same as this USA product.
I have some wheel work to do on some of my bud's bikes and this will come in handy for getting the wheels off while on the lift. Don't know about you guys but, I like standing up when working on the bikes.
http://www.ebay.com/itm/140639098235...84.m1439.l2648
I bought the same scissor jack for less than 100 USD in 2010; the label claims 1,000 lbs so over here this means it came all the way from asia
http://www.hd-outillage.com/cric-cis...d-pi-1528.html
It`s very stable for working and storing the EG preferably without the TourPak. Lifting and landing the bike are done slowly using a 22mm ratchet plus 8" extension but keep in mind not to turn the front wheel to the right as you come down because the jiffystand is on the other side
i bought this blackwidow jack , was impressed with how sturdy well made it was. there outa stock but in a month you can order at a thrifty price.
$59.99 + 18 s&h
On Back Order Until Late Feb. 2012
http://www.discountramps.com/motorcycle-lift-jack.htm
The Black Widow Motorcycle Lift Jack is a sturdy motorcycle jack for a reasonable price. This motorcycle jack weighs 28 lbs and has a lifting capacity of 1,100 lbs to accommodate almost any type of motorcycle. The Black Widow jack features a durable glossy black powder coated finish. The total height range of the motorcycle jack is 3 1/2" to 16 1/4" high. You can get an additional 2"-3 1/4" of height with the removable adapters that are included. To prevent slipping a grippy rubber padding has been added to the top of each adapter along with large bolts on the front to secure them in place. To increase the stability of the motorcycle jack a foot is welded onto each side. The Black Widow Motorcycle Lift Jack comes with a one year warranty.
Product Features
$59.99 + 18 s&h
Product Features
- 6"W x 17-3/4"L motorcycle center jack with a 7/8" adjustable lifting socket
- Lifts from 3/4" to 16-1/4"H
- Large 1,100 lb. capacity
- Includes (2) 2" removable frame adapters
- Heavy duty steel construction with a black powder-coat finish
$59.99 + 18 s&h
Product Features
$59.99 + 18 s&h
Product Features
There are many other brands and I have not received this yet so, I will at least reserve that judgment. I have seen and used others also but, saw this brand being used in three different shops and wondered why. This is a lot wider and more heavy duty compared to some mentioned. More expensive than others, yes. I base the value of the tool on how often it will be used and spend accordingly. We will see if that's true.
