Klockwerks
Klockwerks
I got my new windscreen today for my glide, why does it have the hole in the center?If you mont the center down tight the outside holes don`t line up, if you line the outside up the center looks like this. Do you ever wonder why replacement stuff just does`nt work like you think it should?
I think it is not fully down. Loosen all three fasteners and face the front of the shield and pull down.
Nice looking shield. Call Klock Works and ask. They are the best at customer service.
Is their a rubber that slips onto the bottom of the shield. Maybe it is not slipped onto the shield and blocking it from going all the way on.
That's all I have.
That's all I have.
Mine did the same thing. I found you had to get the side holes lined up, then shove the center down. Have the side screws part way in when you do that so the windshield does not slip down on the side. They are a bit of a pain to install but once in they fit and look good.
ok thanks for the advice guys, i see the error of my ways,I talked to makal at kustombagger he said start the outer two then pull the top center of sheild forward and the center will pop in place and it did installed and tightened center screw then sides fits
good looks good, i`ll test it out in say a month or two lol
