I have a turn signal problem...
Do the rear signals work?
Does the bike have security?
Don't bother looking for the flasher there isn't one. That function done with the TSM or the TSSM.
Received 49,966 Likes
https://www.hdforums.com/forum/engin...k-5-times.html
Do the rear signals work? no
Does the bike have security? no
Did you recently rewire something or add an accessory? no
No blown fuses, that I can see... I'll check w/ a test light tomorrow.
Thanks for the link on the TSM/TSSM, I'll have a friend check this out.
Thanks to all who replied....Ride on!!
It is pazling that your rear turn signals do not work - front and rear turn signals on each side (left or right) are connected together.
If you see just the front flashing that means that the rear lighting is disconnected - that may be the reason for the trouble code.
On the other hand you are saying that using the turn switches none of the turn signals can be activated? In such case I would first check the fuses.
If your starter doesn't work either then you need to replace the TSM (or check the connections to it first). Also, verify it hasn't fallen off the mounting bracket.
Do you by any chance have LED turn signals installed? That TSM you have will not work with LEDs unless you use load equilizers.
Reindeer
11
09-27-2012 06:34 AM
