Tour pak/Brake/running/ turn and LED turn signals
Need some help...
When I purchased my 2010 Ultra Limited I added the Tour pak Brake light/Running Light/Turn Signal... HD part number 69200042A so I had additonal lights/turns on the tour pak.
Yesterday I installed a set of LED rear turn signals, HD part number,, 68127-10..
Right turn signal and brake light works as it should... Left turn signal blinks twice as fast and is faint.. I unplugged the left LED turn and now the left tour pak turn light blinks fast as well.. The flasher for the system which is under the tour pak liner must have went bad. I pulled the liner and it is definately the flasher unit.. Are these flashers replaceable?? or do I need to buy the whole kit again?? or is there something else I can do??
Thanks for any suggestions..
Skunk 237
PGR
God Bless our Troops....
Skunk 237
PGR
for your reading
ok before buying anything read this
http://www.cvoharley.com/smf/index.php?topic=52833.0
Before you panic. Remove all the electronics you spent your hard earned money on and plug just the H-D LED's in. You should find they will now work properly. Now you can sell all the electronics you needed for the bulbs for half what you paid for them.
Harleypingman
01-20-2018 12:20 PM
