FM 107, 777 build, dyno results
Old 01-08-2012, 08:37 AM
Varooom's Avatar
Varooom
Varooom is offline
Default FM 107, 777 build, dyno results
I put about 800 miles on my 08 RoadGlide after doing the FM 107 build.I took it to my local dealer yesterday and had it tuned with a SE pro tuner. 100hp 110 tq before tuning,104hp, 114 tq after. I am at work right now and can't post the dyno sheet, I will tonight.
I was hoping for a little more but I must say shee really runs!
Its funny, when it was a 96 I had it tuned after stage 1 exhaust and intake, 74hp, 84 tq.
Two years ago I built it to a 103 with Wood 6-6 cams, 100hp, 110 tq
Now with the 107 104/114. Seems this motor likes to make 10 ft lbs more tq then hp.
Just wierd, anyway I was hoping for a little more but it sure is fun to ride. Now I am debating doing the FM head and throtle body porting or just live with it the way it is?
Any thoughts?
Thanks,
Doug
Old 01-08-2012, 08:41 AM
ArizonaPhil's Avatar
ArizonaPhil
ArizonaPhil is offline
very impressive.
Old 01-08-2012, 09:16 AM
troop's Avatar
troop
troop is offline
Dyno's can vary greatly. At the dealership where my bike was tuned, my stage 1 (canned map) 96" made 62hp/80ft-lb tq. After my 103" build (in sig below but with stock headpipes/slip-ons) it made 97hp/108ft-lb tq. That's an increase of 33%+/25%+ ! Another forum member with a slightly different build than mine made similar #'s at my dealer but had 10/10 more at two other area dyno's. If it runs good, don't look back....
Old 01-08-2012, 09:29 AM
ICIBUY's Avatar
ICIBUY
ICIBUY is offline
So you did the 107 with the 777 cams and didnt do any head work at all? If that's the case... Those are good #'s but head work would probably give you another 10HP? Tough decision but it would be worth it to me :-) does it ever freakin end? LOL
Old 01-08-2012, 09:56 AM
sporacer's Avatar
sporacer
sporacer is offline
Those dyno numbers look to be on the money for that build.
Old 01-08-2012, 10:06 AM
z71_fourwheelin's Avatar
z71_fourwheelin
z71_fourwheelin is offline
Your numbers are darn near matching mine with the same build just different cams
Old 01-08-2012, 09:50 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,161 Likes on 1,354 Posts
Any thoughts?
Thanks,
Doug
104HP/114 Tq is right in there where it should be with stock heads. What exhaust system are your running?
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 01-08-2012, 11:14 PM
steveg56's Avatar
steveg56
steveg56 is offline
Question
Any thoughts?
Thanks,
Doug
So how much did it cost you for 4HP and 4Tq??
Old 01-08-2012, 11:20 PM
dan11809's Avatar
dan11809
dan11809 is offline
If it's tuned right,it looks like it is......fuel mileage will be better also.
Old 01-09-2012, 04:48 AM
electradad's Avatar
electradad
electradad is offline
That is the exact build I plan on doing over the winter. Sounds like some good numbers. Although if I already had the 103", I would have stuck in the 777's, got a good tune and let it go at that.
Quick Reply: FM 107, 777 build, dyno results
