Oil leak ?
Old 01-08-2012, 03:42 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
I know it is hugely popular on this forum to grab the die grinder or dremel and start grinding away on the inner primary to remove stators, usually for a comp change, but I would have to believe H-D put that lip in there for a reason. I have heard it stated a few times that lip is for oil to pool behind and be picked up by the front sprocket, but regardless it must be there for a reason otherwise H-D would have just enlarged or moved the cover forward instead of creating the lip. It is not a huge amount of work to get the primary off, the hardest part is getting at the starter bolts on the older bikes with the rear cylinder Y-pipe. If you have an 09 or newer or changed the exhaust then its really no big deal. Also pulling the inner lets you check out the inner primary bearing and race for wear or failure, which have shown to be a weak point.
Old 01-10-2012, 01:14 AM
aussiesport's Avatar
aussiesport
aussiesport is offline
lots of usefull info there im guessing it is a problem with the leak , but i dont get why harley didnt put the bloody hole str8 up as in at the top of primary so even if you filled the da mn thing rite up it still wouldnt leak out !!!!!!! , me thinks im gunna do the sikaflex thing until i get some dosh to do a belt/ or se comp ! oh and you two buga's make up hey rofl
Old 01-10-2012, 05:16 AM
Beav's Avatar
Beav
Beav is offline
Talking
It's all good auss...
Hopeful ya get it stopped with the silicone.
Hope you and ol' no-bro smokindave have a great day!
Beav
Old 01-11-2012, 05:06 AM
aussiesport
lol no worries beav'o' as always i listen to everything and take a bit of it all and add my own herbs rofl you have a good one aswell mate
Old 01-11-2012, 09:22 AM
Ribitt's Avatar
Ribitt
Ribitt is offline
Cool
If it is still under warrenty take it to the dealer and pay the 50 bucks. My 07 ultra with 79K just started to leak there and the warrenty covered it. No recall just plainly covered under warrenty. my 2cents.
Old 01-12-2012, 09:56 PM
redlohsom's Avatar
redlohsom
redlohsom is offline
checked with dealer, no recall guess I'm going to do the fix like everyone else.
Old 01-12-2012, 10:17 PM
nytryder's Avatar
nytryder
nytryder is offline
I just want to know where the hell is Wally?
Old 01-13-2012, 02:28 AM
Mike's Avatar
Mike
Mike is offline
I won't grind the inner primary lip as a shortcut either. It might or might not be a good idea, the only thing you can say for sure it that it's a faster way to access the stator. Pulling the inner primary might be a little more time consuming (not much), but it's certainly not wrong.
Old 01-13-2012, 09:04 AM
classic53's Avatar
classic53
classic53 is offline
I'm going to throw another idea out there. I also thought mine was leaking awhile back and left it go for a couple of weeks. Well, it started to drip and I was just about to tear into it. I started looking around and found out it was my oil cooler adapter that was leaking. When the adapter first started leaking, it must have migrated to the left side of the bike and then the wind caught it and threw it right on to that grommet. So, before you tear into anything, look around real good first. You just never know.
Durango Dave
11-11-2021 10:21 AM
Runamuk13
05-04-2021 06:05 PM
moblmowr
11-21-2010 07:39 AM
Tanker2
02-08-2009 10:17 PM
Square Dude
Oil Archive (no new posts)
10-26-2005 12:28 AM
Quick Reply: Oil leak ?
