Notices
Battery of The Future?
Old 01-05-2012, 01:43 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Originally Posted by X Iron Butt
After looking back at post #12 I think the no tender needed is talking about the lithium battery and not refering to the LA. That makes more sense because lithiums won't sulfate. When I first read it I thought they were talking about tenders in general. I sure would like to get more than 3 years out of the HD battery. I used Jet Ski LA batteries in my shovel and they held up good. Not sure how much different the new HD AGM is than the Shovel head but when the time comes I will look into it. Probably won't get a battery from the dealer.
Got 6 years and 25k miles on my original battery, never once on a tender and it went completely dead 2 different winters in the garage. If your charging system is healthy, and it doesn't sit for mode than a month without starting you should be just fine without a tender.
Old 01-05-2012, 02:21 PM
Dewky's Avatar
Dewky
Dewky is offline
Cordless power tools all use Lion now, quick to charge and supposed to be good for 10,000 recharges.They dont seem to lose power when just sitting.
dewky
Old 01-05-2012, 02:47 PM
cp1's Avatar
cp1
cp1 is offline
Checked on those about a year ago and couldn't find one with enough cranking amps.
Old 01-05-2012, 02:58 PM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
That is respectable life and I am looking forward to/expecting that minimum. But if you use a tender do you get 10 years. If you go here http://www.yuasabatteries.com/batteries.php#anchory they have some good info on batteries and they don't recomend a tender if you follow their maintenance schedule. I had read this before about the construction of AGM batteries and they still have acid in them and lead plates. My thoughts are if you keep a 13.8 v charge on the battery the acid solution is not as strong that should lead to less dissentagration of the lead and that should give longer life. I have my tender on a retractor in the middle of the garage so plugging in is not a problem. Remembering to get the pigtail off of the pipes when I leave has chalenged me a few times.
joshh
08-22-2018 12:29 PM
jberger711
Electrical/Lighting/Alarm
12-21-2016 02:45 PM
olddude48
12-31-2012 10:02 AM
larry69fatboy
03-11-2010 02:23 PM
tennmoto
09-16-2008 07:53 PM
Quick Reply: Battery of The Future?
