PBR 300x2 Amp Install Problem?
Old 02-29-2012 | 05:56 PM
LACARAUDIO's Avatar
LACARAUDIO
Stage II
I have the PBR300X2 IN STOCK NOW
ALSO HAVE PBR300X4 , PBR300X1 , AND PBR500X1 .
I can ship by ups
Call me at work 310-836-5550
Im in Los Angeles We are an Authorized Dealer
Old 02-29-2012 | 06:50 PM
mgordyan's Avatar
mgordyan
I can ship by ups
how much?
Old 07-05-2012 | 07:19 PM
imdamnedifido's Avatar
imdamnedifido
6th Gear
What were the results of sending both units in?
Old 07-06-2012 | 12:51 PM
VegasKen's Avatar
VegasKen
I haven't done this yet (have my amp but waiting on the brown truck to bring my speakers) but I've read that this amp vastly prefers speaker level inputs to the RCA inputs. This is the first amp I've heard this on in the 25 years or so I've been messing with car audio. Just my $.02
Old 07-07-2012 | 01:18 PM
DRM510's Avatar
DRM510
i have also heard this but never got any solid evidence that made me wanna cut the rcas off my wiring harness. the guy at the stereo shop gave me a weird look when i told him i heard the amp prefers high level input. so im curious to hear if it makes a difference in the performance of the amp. b.t.w. where did u read this??
Old 07-07-2012 | 01:27 PM
vtwinhd59's Avatar
vtwinhd59
This is your solution. Just did mine. The sound should be awesome hooked up with the high level inputs. Just cut the RCA connectors off and be done with it.
Old 07-07-2012 | 01:39 PM
VegasKen's Avatar
VegasKen
.......... b.t.w. where did u read this??
I FIRST read about it on here. Its in 4 or 5 posts. I also saw it on 3 or four other car audio forums.
Old 07-07-2012 | 01:40 PM
VegasKen's Avatar
VegasKen
I was skeptical because that's exactly opposite of every other amp I've ever installed. I will be doing my 300x4 that way when my speakers get here though.
Old 09-06-2012 | 01:26 PM
UltraNutZ's Avatar
UltraNutZ
this is correct information and also, when using high-level speaker wire inputs instead of the RCA jacks, you do NOT hook up the remote wire.
I've read post after post after post of this and what's happening is folks aren't reading the install manual properly or simply missing the notation about high-level inputs. The amps are designed to turn themselves on with the high level signal from the radio. (THIS ONLY WORKS FOR SPEAKER WIRE INPUTS, NOT RCA INPUTS) This configration then turns the remote wire on the amp into a "remote out". If you do like others and connect the remote wire to accessory power, the amp will then feed power back into your accessory circuit causing you to stand there and scratch your head saying WTF after your turn your ignition switch off and your dash lights stay on and your radio continues to play.
Old 09-06-2012 | 09:22 PM
Goodboo's Avatar
Goodboo
I'm about to do this install myself. Any links or walk throughs available? Not sure how or ware to run the power cords.
