My 2010 Ultra seems to be going through a lot of rear brake pads. I've got 19K on the bike, replaced them at 14K, now they are squealing again - 5K later. I only use the rear brake in low speed situations, relying heavily on the fronts to slow me down before I apply the rear. Seems on my other bikes, I got 20K or so out of a set of pads.
Squealing is not an indication that new pads are required. Are the wear grooves still there?
These new Harleys are so much easier to pull the calipers and check the pads. If the grooves are still there, you don't need new pads. Clean the calipers to take care of the squeal.
Cool thanks. My previous pair squealed and had about 20% left when I changed them. I'll pull these and take a look.
There's no need to pull the calipers and/or pads to check for wear. You can see the thickness by simply looking as they are installed. New factory pads are .150" thick to give you a reference.
Now if you suspect cracks or some other defect then you'd need to pull the caliper and/or pads to inspect for such defects.
I just measured my rears while I was swapping the rear tire and they are .135" thick with 20,000 miles on them. So mine have worn 15% in 20,000 miles.
