Some 95" tool and gasket questions
RE: Some 95" tool and gasket questions
ORIGINAL: dawg
What size PVC pipe and what size thread rod would I use to make a piston pin puller?
Steve
ORIGINAL: maineultraclassic
You don't need any special tool to remove the piston pin. Just take a long extension and a socket that is slightly smaller then the pin's diameter, and tap it out with a hammer.
Steve
ORIGINAL: dawg
Steve
ORIGINAL: dawg
Didn't think of that, thanks. How did you tackle the pin circlip without the special tool?
Getting them back in..........that's a different story. Make sure you have rags in the case openings to make sure they don't fly in there, and keep your hand over them when trying to reinstall them. I used a small set of needle nose pliers and a small blade screwdriver. I pushed in one side of it and held in place with my thumb, then I used the needle nose pliers to grab the other side and push it into the groove. The small screwdriver is then used to push it all the way into the groove.
Make sure it is fully seated in the groove.............it would be very vey bad if it wasnt.
Steve
Shawrco
Exhaust System Topics
01-23-2013 04:01 PM
