Cam Cover Gasket Leak
Old 01-04-2012, 02:35 AM
dickey's Avatar
dickey
dickey is offline
Received 5,678 Likes on 2,542 Posts
I am having a similar weird issue. There is always a thin film of dirty oil on the clutch cable fabric where it passes under the cam cover. Not enough to even make a drop, but just enough to make me wonder. Seems I read something somewhere about a clutch cable leak--the fabric is worn through to the cable in the area in question, so maybe the cable sheilding is worn & I'm getting cable lube leaking. I know it's a long shot, but it's more of a mystery than a nuisance. everything else in the area is dry.
Old 01-04-2012, 08:48 AM
atrain68's Avatar
atrain68
atrain68 is offline
Now that I've had time to think about it, the same thing happened to me and it all traced back to the oil filter assembly that is part of the oil cooler installation.
Your oil filter might be sitting on an adapter assembly. See figure two in the link below. The gasket behind this adapter is prone to leakage. Ask me how I know. Get some Permatex Ultra Black Silicone sealant and dab sparingly on both gasket surfaces. The black version is very oil resistant. That will create a seal that will solve the leakage. Torque the fittings to specs and let the sealant dry overnight.
http://www.harley-davidson.com/en_US...ts/-J04739.pdf
Old 06-08-2012, 10:24 PM
alstrud's Avatar
alstrud
alstrud is offline
I finally took the adapter off and added the sealant around the gasket as suggested. At first, I thought that solved the problem, but after a couple of rides, the oil started to appear again. Turns out it was the two hex plugs in the outer edge of the oil cooler adapter. Somehow, they were never totally tightened, or worked themselves out. In any event, I tightened them down as much as I dared, and it seems to have cured the leak. Thanks for all your help...these forums are great!!!
trigger1911
Engine Mechanical Topics
10-29-2017 01:07 PM
Mhoffer
18
05-15-2017 03:26 PM
MrFxrs-sp
EVO
06-07-2010 04:23 PM
dog116929
07-01-2009 09:21 PM
SGMAN
04-10-2009 02:44 PM
Quick Reply: Cam Cover Gasket Leak
