Backrest
Backrest
Anyone using a non Harley backrest on a stock seat? I purchased the Harley one and it pushes me up too straight. I have the mount as far back as it will go and I'm still too straight and my arms are too bent. I am much more comfortable without it. Any suggestions on another brand?
I am 6' 250lb. Found the stock seat pushed me up too far on the tank. Had adjustable backrest but still too cramped. Switched to Mustang wide solo w rider back rest and passenger pad. Works well and comfortable. But...I am considering pull back handlebars because the Mustang sits back further than stock and I like having my arms bent a little. I just felt like the stock seat was too far forward.
I have a Utopia Drivers backrest with the 1/2" push it back option they offer (on my stock seat) ... the HD drivers back rest mounts way too tall for my stock seat. the Utopia is a lower mount (or taller if you like) and with the 1/2" back option it made all the difference for me. The under seat mount is nearly the same as the HD one but they are not interchangeable ... the adjustment is a screw on the back side that can be turned while driving though it doesn't usually need much adjusting, I also have the quick detach option
http://utpr.com/harleylinks.html
I generally do not put my butt on the backrest. Like you I have a disk problem L5-S1. Judging from the pics, for me yours would be too far forward also. I want something that will be very slightly behind or even with the back support of the seat. I do not sit straight up in the seat, I lean back a little due to my height and the length of my arms. I find the stock seat and riding position comfortable but I want to add some back support for the longer rides.
I thought about doing that exact thing. Maybe put a 20 deg bend backwards and then bend it back straight again. My fear is that it will temper the metal and it will bend from the weight of me pushing against it.
The Biker's Friend Motorcycle Backrest is very adjustable and able to offer back support as well as storage. Five sizes offered.
