Harley Boom Audio??????
I have a 2006 Ultra Classic with the stock 80 watt system with original speakers, I am looking to upgrade to the Harley Boom speakers also adding the base tour pack ports for the rear speakers. My questions are for those who have this upgrade, first is there a noticiable difference from stock to the new speakers, second do the bass ports make a difference I am not looking for ground shaking bass just a little more than already exists.
If you want to save some cash to spend on other goodies get the hog tunes amp and speakers and get bass ports from HD. Shop around for the amp and speakers and try to get the seller to tell you if the LED power light on the amp is green or red. The green LED is their latest design and works better on HD's than the red LED version. The red LEDs design had a higher start up voltage requirement and the drop seen with Fi HDs would make them not come on every time or drop front or rear at start up. It is a pretty easy plug and play install to do yourself in a few hours and sounds great. The bass ports sound best when going under 35 and when stopped but so does the whole outdoor sound system setup. Be carefull drilling the 2" bass port holes through the tourpack and do it before you remove the rear pods so you can drill through the pod at the same time. I wire tied the wires in the pod out of the way to keep from damaging them when the hole saw comes through. You still have to remove the pod to put the supplied gasket in between the pod and the tour pack. Use a good hole saw and de burr the ABS plastic on both sides of all four holes before re assenbling the pods and installing the ports and lock rings.
I did speakers first and they made a huge difference but the amp really wakes them up. The instructions for the bass ports tell you to get a radio flash from the dealer after installing them. Not sure how much difference this makes but it is another $40 they don't tell you about untill you read the instruction. If you don't have a good drill and hole saw you can buy them with the money you would pay the dealer and still own them when you are done.
BTW if you have a tour pack organizer the corner pockets will cover the bass ports.
Good Luck and as always ride safe.
If you're going through the time and expense of upgrading, why not go after market. The Harley stuff will cost you double. You can get high end marine grade speakers, an amp that fits in the fairing all plug and play. It will sound better when you're done and the cost will be about the same, since you're not going with an amp.
Hawg tunes, hog wired, J&M, cycle sounds just to name a few.
In a few weeks I'll have my system installed. Some parts are here, still waiting for others. I plan on making a photo journal and posting a writeup when done. But loads of people on this site have done them.
Looking forward to it.
HD's installation instructions for the Bass Port Kit are in this link:
http://www.harley-davidson.com/en_US...ts/-J05154.pdf
I'm in the middle of an audio project and have drilled the tour pak and pods for the bass ports. The instructions say to remove the pods before drilling the 2" bass port holes in the TP and pods--pilot holes for the 2" hole saw's arbor are drilled with the pods attached.
I don't see any advantage in drilling the 2" holes while the pods are on the bike; the instructions say to drill the pilot hole for the hole saw arbor, then remove the pods to drill the tour pak and pods separately, particularly since the pods must be removed to install gaskets between the pods and TP; and, if you have a TP liner (as I do since it's an Ultra TP), you'll need to reinstall the liner to mark and cut out the 2" holes--I used an Exacto knife.
Haven't hooked up the speakers and amps. But you can install 6.5" speakers in lieu of using 5.25" speakers that HD uses.
Carl
Carl
For bass port, it's just only holes with nice rings. Here's a link : http://www.passion-harley.net/t32547...adio-classique
But like you i'm curious if it change bass... maybe i'll do it this winter to know
