Gas Tank Leak - How to Fix it?
I have a unique problem in that I appear to have a slow leak somewhere in the bottom of my gas tank. I need to pull the tank again and try and locate it but it appears to likely be at one of the welds. I discovered it when I pulled the tank to change out the bars and there was gas under the rubber caps that cover the front bolts. It was also apparent by the oily sludge that it had been doing it for a while. I cleaned it up and looked for any seepage but could not find it.
Of course the warranty is over and I would prefer not to have to buy a new tank especially with the CVO paintset. If I can locate the spot of the leak, is there any product that can "weld it" up? Something along the lines of JB Weld or the like? It will be under the tank and not visible so if so that would work.
Before I did anything I would be asking HD for a free replacement, as it is a defect in materials or workmanship.
A 2 year old bike should not have a corrosion issue, so I am assuming it is a defect in the manufacturing process.
If HD does not replace the tank, file a report with the NHTSA.
The correct fix? Have a real radiator shop ( if you can find one left) solder the area and pressure test it.. Then repaint the area.
Many of the "Kreme" type products are not compatible with the "new" gasolines, mostly the ones with any amount of methanol added. Ask anyone who had a "Kremed" tank dissolve and fill the carbs with crap.
There is an old sheet metal trick I learnt a while back when we had a large hydraulic tank that had a leaking boss.
If the leak is in the weld and it is a very fine hairline then if you use a centre punch along the crack it may seal up again.
Worked a treat in our case and saved us taking a ring main down a draining a 2000 litre tank! It has never leaked again and that was over 5 years ago.
Not sure it will work in your case but worth a go.
