"Removable rack" for 2 pt. docking?
Old 01-03-2012 | 07:43 PM
painey's Avatar
painey
I only have two point docking, so fitted this rack ($200- p/n 53011-98), of course if you want to remove it the sissy bar has to come off as well, but thats not a problem once you get where you are going
Old 01-03-2012 | 09:33 PM
Ultra89Rider's Avatar
Ultra89Rider
Originally Posted by carltex
I've got the same setup MexiRider has. Works great. I have a T-bags bag with a roll bag on top. I got it at the dealer for $150 I think. Could have gotten it cheaper but was in a pinch and needed something quick.
If you look at the OP, he has a 2011 model.
Harley does not make that 2 Point set up for the '09/Later models.
I think Harley did this because the 4 Point Docking for '08/earlier sticks out so far back.
So Harley made the set up for the Earlier year 2 point Docking station.
But, like I said, they don't fit with the newer models. (maybe that is why they are cheaper too)
Old 01-04-2012 | 03:49 AM
carltex's Avatar
carltex
Originally Posted by bklynbob
Those racks look pretty small. How much weight will they handle?
I weigh 150 and could probably stand on it. It is a pretty strong setup.
Old 01-04-2012 | 01:04 PM
painey's Avatar
painey
But, like I said, they don't work with the newer models. (maybe that is why they are cheaper too)
I know he has a 2011 model but I thought if he is using a two point docking system then the rack I have used will work for him as it attaches directly to teh sissy bar!!!
Old 01-04-2012 | 02:12 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Here's what they are talking about, but I doubt if it mounts just to around the bar does it?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old 01-04-2012 | 09:28 PM
Ultra89Rider
If you notice, it will not fit '09 or later models.
It will not fit the OP's bike.
Old 01-05-2012 | 02:56 PM
painey's Avatar
painey
It does in fact just mount around the bars, I have fitted this very rack to my sissy bar, I know my RK is 2007 but I cannot see any reason why it should not fit any sissy bar that is the correct width, take a look at the Instruction Sheet and can see clearly how it attaches. I think mine took no more than 10 minutes to fit. However once fitted to sissy bar it should NOT be removed.
Old 01-05-2012 | 03:49 PM
Texas Fat Boy
Since the rear tire and fender are wider on the '09s and newer, I am assuming the sissy bar is wider than your's too.
flyingace
08-12-2019 02:35 PM
wrenchguy24
02-25-2009 09:22 PM
2of2
09-03-2008 10:25 PM
tenacean
04-11-2008 03:23 PM
trmn8r
09-02-2006 10:32 PM
