Should I Upgrage Cams when doing Hydraulic Cam Chain Tensioners?
Bought myself the Hydraulic cam chain tensioner upgrade kit along with the required bearing service kit and spacer kit for my 06 RKC. The purpose is due to the potential premature spring tensioner failure. I am not necessarily looking for more torque or HP, however my local indepndent (who I have a good deal of respect for) is suggesting a mild cam change. He suggests that I would appreciate it riding two up and I should see my engine run cooler. I did not know that a cam change can affect operating temperature. If this is the case then I may be interested in swapping cams. Also what parts would be necessary in addition to the cams themselves? I see in the JP catalog, Andrews requires their own chain gears. I am not interested in direct drive. Thanks for any advise and counsel.
You will most likely need some type of tuning device to correctly tune the motor after the cam swap.
My favorite bolt in cam is the SE 204 for a stock motor, however if you ride 2 up mostly then the Andrews 21 will concentrate the power on the low end.
Some have reported running the 21 cams without adding a tuning device.
IMO the MOCO would have gone with a cam more like the 21 if they did not have the EPA limitations to meet.
The 204 cams are more a mid range cam that comes with an ole school idle potato potato along with a slight attitude exhaust note. The 204 will definitely require a device & tune to run properly & reap the benefits.
Bottom line if it were me, yea I would for sure change out the OEM cams but I'm biased & a gear head junkie!
HTH's
HTH's
The cam plate/hydro tensioner kit will include the inner and outer cam chains; you just need a set of cams. I believe the indy's commment about about a cooler running engine is based on the fact that you will need a fuel management system and a tune to optimize the performance of the cam upgrade. The tune will result in a cooler running engine; a cam upgrade without a tune will not.
You might as well upgrade the inner cam bearings in the process; parts are cheap and the labor is minimal once you have removed the cam plate. You will be replacing the outer roller bearings as well. There cam install kits available with o-rings, gaskets, bearings, etc. You will also need some assembly or cam lube.
The Andrews 26 or the SE204 would be good choices for a cam only upgrade in a TC88. You will need a fuel management system, like the TTS, SERT, SEPST, and a dyno tune to take full advantage of the upgrade.
If you haven't upgraded to Stage I, i.e., free flowing A/C and exhaust, you should do that as well. You are about to pay the "Harley Tax".
There is no doubt in my mind that if and when my 03 ever gets to the point I am going to have to go into the cam case it is going to get every upgrade there is including cams.
Now granted I run a stock exhaust, so my gains are going to be somewhat limited, but the whole TC88 engine is designed to meet EPA regulations from the factory, and not to run correctly which is why the first thing all of us did was get a tuner in there.
When my time comes I will also consider gear driven cams
