Cutch adjustment idea
had the same problem with mine and after doing some research found out that the new 96" motor clutches are designed to slip to keep the motor up in the power band so don't worry bout it , dam I should have been a used car salesmen , that really sounded good , any way if your clutch has slipped that much probably glazed or burnt up by now , if you tear it down I would just put in all new disk while you are in there , put the screaming eagle in mine went to the formula + oil in the primary and no more problems
the bike has about 15k on it, i doubt the clutch is shot.
i did the adjustment like i stated i wanted to, i got a polar ride tomorrow, so ill see how it does.
im planning on a SE spring for it here shortly..
Received 2,529 Likes
PoetryJoe
02-24-2018 09:21 PM
