Gerbing's Rocks
At 30 - 40 degrees you're just teasing that gear. I've done full speed interstate rides, long distance, with temps in single digits. The Gerbing gear will keep ya toasty warm.
Oh, any my solution for the controller is to clip it to the front pocket on my vest. That has worked very well for me for several years. And it works no matter what bike you are riding.
Went for a New Years Day ride, decided to wear all of my heated gear. Started out sunny and nice about 50* didn't need the gear, but all of a sudden it got dark and started to get wet and cold. Sleet and rain for 40 miles. Got to tell you all I did was turn on the gear and I was toasty warm.
If there is anything you really need to buy if you want to extend your riding season, then you should "invest" in the HD/Gebring Heated jacket, pant liners and heated gloves (G3 is what I have). Haven't met anyone who says anything bad about the gear yet. I have to say I plan on riding till the first real snow and then I will debate once the salt goes down, may be I'll ride the Metric then, but I will try to be a 12 month rider.
^^^the optional $10 clip case for the heat controller is really pretty much a must have, don't know why they don't include this as standard. Having to hide the controller inside a pocket and then remove it for adjustment sucks compared with being able to clip it to the outside of your jacket and adjust the temp while riding. The wireless controllers Warm&Safe make, make a lot of sense when you can just velcro them to the tank or other area of your bike when you consider this.
When I first got a heated jacket liner I used it to replace my regular insulated liner. This worked well down to ~40F but much cooler and I find the best setup is with the heated liner under the regular insulated liner. The Gerbings heated liner does not seem to have much insulation on it's own. With the insulation over top I can run it on a lower setting and get more even heat with fewer drafts.
