According to my Gerbings instruction, you should start the bike before you plug it in if the control is preset to a certain level, or plug in with the control off, this way, full current will go to the starter.
Thanks guys. My dealer told me they put a fused wire on the acc switch for heated gear et al. Just thought I would use it. I'll try it with the bike running and see if it heat up better. If not I'll wire it to the battery. Hopefully the jacket isn't a dud.
