Please tell me if Zumo 550 wil work as I describe below
2006 Ultra
Zumo mounted on cycle with the patch cord going from Zumo to the HK radio (covered)plug. Then, use my 7-pin connector adapter (the covered plug on the top, left of the gas tank) to which I plug in earbuds. HK radio set to AUX. Will I hear the Zumo directions through the earbuds? Do I have to set the radio differently or is the AUX mode correct? I read and read the HK radio instructions but don't get the picture clearly of what I can do and how for this.
To be perfectly clear, I do not care about music or anything but hearing the Zumo driving directions. Can barely hear them through the speakers, sometimes not at all.
Thanks to all who answer.
When I first got my Zumo 550 I had the dealer set up on my new 09, for the 2 year warranty reason. The way they did it was the same way you did. How it works is, you have to pick between listening to the radio or the GPS on Aux, not both at the same time. GPS will not cut into the radio. I did hear, not sure where, but never tried, loading the GPS SD card with music will do both when listening to it in Aux.
Exactly how I have mine set up. I have a 4gb sd card with hours of music. Keep the radio on aux and listen to music. The GPS will stop music, make a beep and give directions, then go back to music.
I believe that Garmin says that it will only support a 2gb card and up to 500 songs. If you use a larger card as I did, it will work. It just takes a little longer for music and maps to load.
I fooled with it a bit this evening. When I plug the cord into the AUX port on the HK the radio automatically goes to AUX. Then I fooled with the speaker rocker button. All the way rearward (toward back of cycle) with the light illuminated gave me good radio sound through the ear buds. I have yet to hook up the Zumo to see if the directions will sound as good. I was listening through the 7-pin console plug-in.
When I attach the Zumo will the radio be silent? Sounds as if that is how it works and that is fine with me. If just unplug the AUX port the radio will play again I'm guessing. Not a big deal since I velcro the AUX wire to the handlebars.
As I said, I don't care about the music anyway. I just want to hear directions. Thank you for all the help.
2006 Ultra
Also, the 550 has an internal volume control that can adjust volume for the GPS instructions and for music. Ensure they are set on 100% for maximum volume through the radio.
Excellent. I now wonder if there are earbuds that have a heavier cord connection. The ones I bought were not cheap, but the wires are so thin I bet I damage them one way or the other quite soon. The sound quality is terrific though.
Anyone know of earbuds that have stouter wiring? There must be a reason why the wiring is so thin though.
Thanks.
Thanks.
