Can you help me understand the difference in wheel specs between '07 and '10
On the front...the wheel I'm looking at is a 18 inch Agitator. I've read that only Agitator rotors work with the Agitator wheels. Even after swapping out the bearing will I be able to use the Agitator rotors even though they're off a 2010 or was I given misinformation? Hoblick, does it matter that the wheel is an Agitator as far as the rotors are concerned?
Thanks
try this thread, member on the forum here did a great walk through of the process
https://www.hdforums.com/forum/touri...-sg-today.html
