pingle chock
pingle chock
Recently purchased a used Wells Cargo MC trailer. It came equipped with tie downs and a pingle chock installed. My question is , as I have not loaded my bike yet, when I drive into the pingle chock will it hold the bike upright until I get it tied down? I have an ultra classic. What is the procedure for loading with the pingle chock?
If not is there another chock that will hold it upright until it is tied down?
Thanks for any info.
If you have the Pingel Model Cycle Jaws, yes to will hold your Ultra upright while you tie it down. I you have the standard U-Shaped Pingle Chock, no it will not hold it upright. I personally like the Condor Brand Chocks (the Alumnium one). I also have the standard Pingel chocks that I use on my small trailer. No problem to use it just put your Ultra on the side stand, put a tiedown strap on the side stand side slighty tensioned and go to the other side and install the second tiedown to pull the bike upright. I also tie down the back of the bike (lots of people think this is over kill) because you never really know what is going to happen out on the highway.
TN Houndog (08-02-2018)
One other thing to keep in mind regardless of which type of wheel chock you end up using, make sure that when you attach the tie downs that you go to the frame and not the handle bars. The frame or crash bars will give you solid mounting points for the tie down straps, where as the handle bars could bend when used to tie down.
Like huddle, I too tend to tie mine down in the back when trailering. My think is by tying down in a couple of spots it minimizes the chances of finding the bike laying on it's side because a strap slipped.
If you have the standard hoop style Pingle chock it will not hold your bike upright while you tie it down. It's not an issue and a couple of practice tie-downs will have you proficiently tying your bike down solo.
Here's a tip that makes it even easier: I made some blocks (2x4's or 2x6's) that I place underneath the forward part of the frame tubes. They hold my bike upright so I can tie it down solo and also provide a high degree of stability if you cinch the bike down onto them.
While there are those that go to great lengths to tie to anything but their handlebars I've never had a single issue tying down with the bars in over 40 years of trailering bikes of nearly every type. Get some soft ties to go 'round the bars at the bend next to the steering head and cinch her down with ratchet straps. Good advice to tie the back of the scoot also (keeps it from moving side to side).
Gozzie (08-02-2018)
Again, what a genius mind. Thank you
I use the exact same tie down procedure as Huddle and have never had a single problem. Kuryacan (sp?) makes a neat little tie down bracket that attaches to the signal light mounting points on the forks that I use and like really well. Just put your bike in the side stand while it touches the wheel chock, install the left tie down and take up the slack, install the right tie down and tighten till the bike is in the upright position and you are done with the front. I DO use tie downs on the rear and use the rear floorboard mounts as the tie down points on the bike.
Nellybelle
11-26-2006 01:37 PM
