Air Shock Specialty Fill Valve??
12-29-2011, 06:53 PM
Is there such a thing? How do you keep oil from coming out when removing the air chuck when filling and or checking air pressure? I have independent Schrader/ Air tank valves on each shock. Do I need a valve from HD?
12-29-2011, 07:08 PM
Oil does not come out. Unless of course at some point they were over pressurized and blew the seal. The limit is 45 - 50 psi.
Only use the HD pump or a very low pressure bicycle pump.
12-29-2011, 07:18 PM
Manual says to pump air in to push the oil back down the tube then let air out.
skynuts1
08-24-2010 07:35 AM
28gauge
09-08-2009 03:16 PM
BlackFLHR
11-23-2008 08:49 AM
garcon
06-01-2008 09:39 AM
BigBuddy
05-30-2007 10:59 PM
10 ,
27 ,
air ,
chuck ,
cm ,
davidson ,
dia ,
fill ,
harley ,
mm ,
shock ,
shocks ,
threads ,
tips ,
valve
