Chrome Tour-Pak Hinges
I know there have been a lot of postings regarding the installation of the chrome tour-pak hinge upgrade over the years. I am getting ready to make the switch. However, I feel the instructions provided are not as complete as they should be. I am looking for information from the forum members regarding how to make the installation as mistake free as possible. Your suggestions would be greatly appreciated.
I can't help you dealer did mine. Something about me drilling next to perfect paint got me nervous. If the tech screws up,oh well new lid or bottom from the factory. If I screw up,I'am **** out of luck. I do agree that they are way better than those cheap pieces they put on at the factory. The MoCo should be ashamed to put that crap on $25k bikes.
I did my hinges last fall. it is well worth the effort. They directions are correct about removing the hinge pin first along with the tether. this removes the top lid of the tour pak and you can work on it separately. I made sure i had new drill bits , painter tape, and duct tape. I drilled out my rivets with a variable speed cordless with new drill bits. I could control the drill out process good this way. Just let the bit do the work. There are a few options on how to remove the rivets some guys use a dremel. I found the drill bit worked fine as long as it was a good sharp new one. To remove the tour pak lid rivets I used duct tape to pull the gasket up and over the lid to keep it out of the way of the bit. once the rivets are out its all down hill. I also use some red lock tite on the new hinge screws. If you can have a helper to hold the top lid while you attach the new hinges it makes it much easier. You can also go to the dealer and have them do it. they shouldn't charge more than 1 hour labor. if they want more than 1 hr labor I would forget it and do it myself. good luck, either way you'll love and from now on you seem to notice everyone else hinges. even on the CVO's they put those cheap hinges on. Jeff
