Chrome Tour-Pak Hinges
Everyone has already talked about the drill bits and how to remove the old hinge.
One more thing I found is after the installation. The screws were tightened to the amount needed as in the instructions. But after 6 months, the vibration cased two of the screws to back out.
I took Blue Locktite and have had no more problems. (I did it to all of the screws)
I held the seal back with a putty knife and drilled the rivets from the inside. The dimple on that end of the rivet hold the drill bit in place.
Did mine this week and followed most of the tips here.
a couple of things I found........
follow the instructions and remove the hinge pin from the strap hinges and separate the top and bottom. I placed the top on a heavy quilt on a work bench.
I used a very sharp 5/32 bit and variable speed drill motor to slowly drill the rivets out of the bottom first from the inside. Go nice and slow and don't use too much pressure. They drill out pretty easy. I also held the hinge and the inside plates together to keep them from spinning using a pair of long nose vice grips (may be over kill but I am cautious).
Have someone hold the top while you slowly drill out the rivets. I used duct tape and my fingers to hold the weather seal out of the way.
After drilling.... remove the hinges then go back with a 3/16 bill to drill out the holes so the bolts and the studs for the top will fit through properly.
Definitely need at least 1 helper to hold the top while you install the screws.
I used red locktite to help keep them from vibrating out.
Overall easy job....intimidating but take your time and anyone can do it. Definitely worth the work as they look 10X better.
