Help me decide if I need these tools
Preparing for my tensioner upgrade/cam project. There are some miscellaneous tools that I know will make life easier, but also aren't really required. Trying to keep the project reasonable from a cost standpoint. Let me know what you think is worth paying a few dollars for. For the record, I will be going in through the top.
Special rocker box wrenches -- Use a common box- or open-end wrench, as it will save $40 at the expense of a bit more time. If I were doing cam jobs every day I would buy the HD wrench or something similar, but not for one job per year or less. Mrnone's idea of cutting an Allen wrench might speed things up a bit compared to the above.
Dogbone torque adapters -- Some of the bolts weren't accessible for a torque wrench, but I simply used a nearby-reference to tighten them. IOW, tighten one to torque specs and the inaccessible bolt the same number of turns after seating.
Oil pump alignment screws -- My manual says nothing about any oil-pump alignment screws, but there is a procedure for centering the gerotors as Djack mentioned earlier. I didn't remove my lifter blocks, but I think you'll need some alignment pins for these if you do. I clipped the lifters in place using large binder clips from Office Depot.
I have or will have the major tools like torque wrenches, bearing puller, the manual, etc. It is the miscellaneous stuff I'm wondering about. Thanks.
I like the Motion Pro pushrod clip tool. That is a big time saver. Buy a tool of some kind. The screwdriver method sucks.
No need for the torque adapters.
Earlier models need the oil pump alignment screws but I do know the 07 and later models do not.
The rocker box wrenches significantly reduce the hassle factor of getting into the tight spaces, but are not required. I ended up buying these tools and have no regrets.
Dogbone torque adapters. I bought them from Snap On for $30 each, but not necessary. They do give a good feeling for using the right torque. The bolts on the rear cylinder head rockers are hard to get to and these make it easier to do. Even if I use them one time on my bike, they can be used on other things.
While I was waiting for responses after initially starting this thread, I ordered torque adapters. I got 1/2 inch and 7/16 for a total of less than 40 bucks. I have a tendency to overtighten everything and don't really trust myself. I also got the oil pump screws for 11 dollars. My 04 manual calls for them. Don't know how things change considering I am putting the newer style pump and support plate in it. I'm sure they can't hurt for 11 bucks. How hard is it to avoid scratching the crap out of the chrome on the rocker covers if I just use a box end wrench? Still weighing the pros and cons of nice to have vs not really necessary on a couple things.
