trailering wheel chock
#31
2 trips to Sturgis with my Raptor TH ( and wide glide) and no good tie down for my bike. I just used the d-rings and a wooden block, Guess what, the bike pulled the D rings right out of the floor on the 2 trip out and bike fell over in the toy hauler, very bad experience. Now I have a Condor and a ultra classic. The tie downs in the toy haulers are rated for heavy loads. I replaced all my recessed tie downs with 6k lb solid rings. I had to chisel the floor like a extra 1/2 inch to fit the bigger rings in the floor. Its easy, I would highly stress to you to replace them with these...
http://www.pj-parts.com/Product-D-Ri...d.-6K_729.aspx
I took my new Ultra classic and the TH to Sturgis in 2011 with the new D- rings installed and the condor, along with 3 bikes all using the installed D-rings. They were as solid a a rock out and back. A Huge difference in the tie downs.
It takes a little extra work to drill in the 4 thru bolt holes but its better than having your bike fall over. I Put large washers underneath the trailer where the bolts come thru and lock-tite them then spray with rustolem over the bolts. This along with a condor setup with the quick release works great. I just roll the carpet over the condor latch and the d rings and you don't even know they are there until its time to pack up and load the bike. Jeff
#32
i looked for a while and went with the wheeldock. i drive in and it locks up the front wheel real nice and i can do it by myself. fairing on my flhtk is close to the sides so i wanted something easy that would hold it in place pretty good. i put 2x6's under the frame, pull it down in four places to etrack with the big wide straps and it doesnt move. its made in usa too. good luck.
tin
tin
#33
E-track. Several posts have said the track is available everywhere, but I can't find a store named everywhere. I went by the dealer and he checked the Drag Specialties catalog and they show some of the chocks and braces, but no e-track. Camping World where I took the truck to get the hitch installed suggested the dealer. Haven't checked the home improvement stores but just don't think they will carry this. Anyone have a suggestion to an actual store that carries it? For my application I figure 7-8' sections needed.
