shock lengths
the street glide shocks are about 1" drop ( really .75")
the drop is taken from the shock travel, so instead of a 3" travel, the shock has 2.25" travel--- translates to a slightly harsher ride.
the 09+ version are "revalved for smoother ride" from the earlier version.
I have them on my 2009 EG Classic and they are fine.
I put the stock stocks on when touring, swap over takes maybe 20 minutes.
Mike
Mike
Don't do it ! stick to a 13" shock, if you put HDs 12" SG shock (or any aftermarket) on not only will you lower your bike but you'll also lower your spinal column another 1". I put Ricors on so I don't have to keep messing with the air pressure and went to 13" on my SG. If you put a lowering bracket on you will also stiffen up the rear to much. It depends if you use your bike for distance or shorter rides. If you have a shorter inseam try a lower seat. IMO
