move license plate below taillight
Seems that Softbrake relocation plate doesn't fit 2009-2010 Road Kings. At least fitment table in J&P Cycles web page says so. Don't know the reason. Maybe fender width?
Road King original set would be ideal but expensive. If you remove the fender tip there is a set of holes you can use. If you buy a couple of door stoppers between the fender and license plate sized metal plate you can build relocation kit your self ;-)
When I'm done I will post a picture.
If you are unsure, just call them, they are very responsive. (208) 561-5031
https://www.softbrake.com/shop/produ...dgroup=License
It's so wrong if you in the UK have that fixed already. In Finland even the dealer was out as a snow man when I asked for relocation. Do you by change know the price of that UK assembly? It should be the whole EU assembly to be fair ;-)
I used the RK light assembly on the rear of my 09 EG Classic,which I think is similar to the UK setup.But I doubt there is room for your plate below the tail light.My plate is 4"or 5"X 7" and yours looks somewhat bigger.
