Mini beast airhorn
I put one on last summer. It was very easy to install. Be careful not to put too many connectors on your battery terminal. I already had a battery tender and a gps on mine, so I wound up putting on a simple bus bar and hooking everything up to that. I don't know why HD doesn't do that at the factory. Anyhow, I am totally satisfied with the mini beast. Ride safe.
I got a chromed mini-beast II (I don't think the make the fully chromed ones anymore....I had a hell of a time finding it) a few weeks ago but haven't installed it yet.
Basically what you get is a Stebel Nautilus air horn which sells for about $40 and the rest of the goes to a big honkin housing made of VERY thick aluminum and all the wiring including relays and battery terminals so the installation is pretty much plug and play. The thing really is a beast.
I've had the Stebel Nautilus horn installed on most of my vehicles and it really IS the loudest horn I've even heard in my life that didn't require a large external compressor. It's bowel-viodingly loud. It's VERY effective. When you sound it, people start looking around. I wouldn't recommend putting it on your bike unless you ride with ear plugs ALL THE TIME because it's rated 139 dB @ 1ft. Since your ear is going to be roughly 4 ft. from the horn you're still looking at about 128 dB - you will probably experience temporary hearing loss, and possibly permanent hearing loss as well.
There is surprisingly little lag when you press the horn button (you'd think there would be some because air pressure has to build up before it will work but it's pretty instantaneous). Depending on how you mount it, you may hear or feel the compressor running when you hit the horn button. A couple rubber washer or a bushing (you'd have to make the mounting hole bigger) may help with that.
I would definitely recommend it. If you don't want to pay all that extra cash for the housing, you can still get the same exact effect with a Stebel Nautilus horn (just google it, you'll fine tons of them....even a chromed one)...especially if you want to put them on your cages after you hear it...they run like $40.
One word of warning....make sure you mount it with the horn openings DOWN, otherwise if gets water in it, it won't be able to drain out and not only will it sound silly but the water will ruin it.
I just got done taking off the H-D air horn - lag of an air horn, lack of "crispness", wanting something louder, etc.
As another less expensive option, I mounted 2 Fiamm Freeway Blasters each rated at 130 db. I kept the relay for the air horn, mounted one of the Fiamms under the original cowbell and the second is mounted to the frame plate immediately behind the motor (nut, lockwasher and fender washer was all that was needed), wired in parallel. I installed one low note horn and one high note horn - no lag, lots of crispness, great harmony <grin> and plenty loud.
Oh, and did I say cheap? $6.59 each plus a relay.
http://www.ryderfleetproducts.com/ry...oductDetail.do
Location: Ottawa, Canada, summer, Daytona Beach Florida, winter
1 Post
Instructions are good, just make sure you get a good ground, the rubber mount from the to be used horn mounting bracket do does not allow a good ground. I ran a red wire back ti the battery and a black wire back to a frame ground under the seat. I bundled the 2 wires in a black wire , don't even loom so you don't even notice them.
This is one loud horn, my only comment is it sticks out a long way from the side of the bike.
Good luck!
Good luck!
