Exhaust fitment wuestion
I just installed a Bub 7 true dual exhaust system with bub mufflers on my 2012 FLHX. I was not impressed with the routing of the pipes, nor the set up they created to support the left exhaust pipe. The rear cylinder exhaust makes such a sharp turn that its nearly impossible to tighten the the lower exhaust manifold nut, and the pipe is so close to the left passenger footrest it will toast a passenger, as well as melt the footpad. Anyways, I want to get a Vance & Hines true dual exhaust. (Which I should have done in the first place) My question is can I use the Bub 7 mufflers with the V&H exhaust or do I have to buy the whole damn set up? Thank you.
beefcake.
Screamin Eagle CVO Models
07-06-2012 03:19 PM
FLTR2008TRIKE
06-28-2010 06:17 PM
