Anyone install a K&P Stainless Mesh Oil Filter?
#61
2. As far as micron size is concerned, do you realize that your paper filter can pass particles 50 microns or larger and be labeled "10 micron"? They use a Beta Ratio test & it only requires half of the trapped particulates to be 10 microns.
3. Define "devastating."
#62
1. I didn't speculate anything. It's pretty clear, from a "scientific standpoint" that if you believe my guages, my oil pressure increased and running temperature decreased. Do you have anything "scientific" that disputes this or any other claims?
4-10 microns is the clearance between a piston ring and a cylinder wall, so a 50 micron filtration is useless. How do I know? I have spent thousands of hours and millions of miles testing fleet equipment and the results before and after, and one thing for sure no one I have ever heard of in the last 40 years runs a steel wool filtration system.
I guess its a religion not a science. Just my opinion but anyone can spend their money anyway they want.
#63
I am talking about filtration, a steel wool element Youth You'd more than a paper element, it will also break down over time and provide less filtration. Wheres the documentation that a paper filter rated for 10 microns will pass 50 microns. Thats just plain false advertisement. But the only true to filter down that low is through a low pressure, cant do it under high pressure.
#65
On their website
"type 304 stainless steel micronic filter cloth"
http://www.kandpengineering.com/tech...ghlights.shtml
#67
#68
TUCCI
07-10-2020 11:42 AM
